msteinblock
Picked up a 48 G and got it running ok by just swapping one bad spark plug wire. Started ok, idled ok, but pretty rough at faster rpms. Replaced the carb (new, not rebuilt), new wires and new 3116 plugs. (Did not touch the mag) Now I have different issues. It will barely start. One side will fire once, then it will barely spin until it fires again once. It may do this for a bit and either die or all the sudden take off and idle normal. Once running, idle and fast idle seem fine. I can take it out and drive it, last night had it out driving for 30+ mins, got it up to temp and never missed a beat. With one catch, when trying to move from idle to anything faster it will almost act like it is flooding out. If you throttle up ever so slowly and slowly get it rolling in gear it will make it. If you throttle up too fast or put the clutch in too fast it will act like it cant get under itself and almost die. I have adjusted the carb over and over trying to get that cleared up with no luck. (It had this symptom on both carbs). I am not sure where to start focusing my attention. Part of me says carb but I have a hard time with that knowing both have the same symptoms and one is brand new. I mention not rebuilt as I know it has been discussed here many many times that rebuilt carbs may not have gotten cleaned properly. Wires? (Do I need to get a different/better brand?) Different plugs? Replace the mag (not sure a mag would show these symptoms?)
Thanks in advance for the help!
