(reply to post at 11:53:21 09/11/20)
(quoted from post at 20:43:07 10/19/21) The June pic of cylinders 3 and 4. The head bolt with a fitting? in the lower left, did MM add a hollow head bolt to help hold things together while still using that "tube" to send oil up to the rockers?
I'm still stuck in 20-35, 21-32 FT & FT-A four cylinder era. You know those tractors as well.
This is interesting to me and makes sense why there are G-1000 pistons and rings in my fresh 21-32.
(quoted from post at 02:54:29 01/08/22) The Vista has returned to life.
(quoted from post at 23:54:29 01/07/22) The Vista has returned to life.
(quoted from post at 16:26:18 04/26/22)
Looks better each time. Now you need the pump.
(quoted from post at 11:54:04 04/27/22)(quoted from post at 16:26:18 04/26/22)
That will be the next big step.
Proper front tires were put on it after that photo was taken as well.
(quoted from post at 01:34:43 04/30/22) I can almost hear that big Minneapolis six.
SW, are those big bruisers as sweet to operate as they are to look at?
Neat thread!
(quoted from post at 16:33:55 01/07/23) Looks like the toe-in needs to be adjusted.
MMDEL
(quoted from post at 08:56:41 01/10/23) Hey that sounds good, I just might keep it for awhile.
MMDEL
(quoted from post at 02:04:35 01/11/23) If I may.
I've had you confused with another fellow while enjoying your thread.
Where did MM stash the G-1000 oil filter/s and for my filter studying, would you click a pic of your oil filter setup?
I'd like to see it.
Thanks. Du![]()
(quoted from post at 09:10:41 01/12/23) SW: I've been standing here for several days now, when do I expect the truck????? It is supposed to get colder and it is going to be hard on me. I would do a lot to have a Vista, but this is ridiculous.
MMDEL
(quoted from post at 10:07:27 01/13/23) That would be great. But I am fussy. It has to be LP with a late good cab.
MMDEL
(quoted from post at 15:10:30 01/15/23) Yeah I know, story of my life. I'll keep hoping and looking.
Have a good year. I'll send that part shortly.
MMDEL
(quoted from post at 09:23:17 01/16/23) I'm not that smart.
MMDEL
(quoted from post at 15:33:16 01/17/23) I'm not sure she was that smart either.
MMDEL
