G1350 Injection timing
f5erg7g6
Finally got tired of leaks and always needing to prime our old 1350, so I decided to spend some money on the fuel system (new
injectors, rebuild pump) When i was going to put the pump back on the other day, I look in the book to get the static timing,
and i was perplexed to find it is factor at 4 degrees ATDC. I figured it would be at 10-15 degrees BTDC. MY main question is, is
4 degrees in fact correct and should i set the pump there or give it more timing? Thanks. Any input/knowledge would be good.
Pumps can be timed beginning of injection, OR end of injection like most Stanadyne/Roosa-Master pumps are. End of injection is used most on IH, JD, Oliver, Case, and MM engines with Roosa pumps. AC, MF, Perkins Commonly use beginning of injection pumps.
