Gas Air Compressor
Howard H.
I'm looking for a good gas air compressor.
The local Lowes has a "wheelbarrow" Hitachi with Honda engine ($750). Home Depot has a similar Senco unit for about $150 more.
Does anyone have any comments pro or con over those two brands??? Or recommendations for another brand to consider??
Thanks a lot,
Howard
I really can not help you with one brand over the other, and I suppose that you must want a portable unit instead of an electric one, however the one most important lesson I had to learn over the years, of buying several compressors, is proper C F M . Gallons of tank space, and high PSI, can not provide the amount of air, that I was looking for. I got tired of waiting for air to build up, so I could go back to work. When I finally bit the bullet, and bought a 27 CFM unit, I found that I had enough air to run my tools, without waiting for air. I actually hooked a large 1000 gal, home propane tank, to an 11 CFM craftsman compressor, trying to run a 7" air sander, and still ended up waiting for air. Nothing replaces adequate CFM.
Check out eatoncompressor.com. They have a very good 6.5HP Honda 10 gallon portable air compressor. I bought a compressor from them a year ago, great product, great warranty, great folks to deal with. They also have the same compressor for sale on eBay, without the engine, item number 130360057638. You may be able to buy a cheaper engine like the Powerhorse from Northern Tool, put it all together yourself, and save some money, it will depend on what the shipping will cost on the individual items. At any rate, I highly recommend the Eaton Compressor products. I don't think you can buy any better for the money. Hope this helps!! :wink:
I have and prefer Rolair air compressors whether gas or electric.You pay more up front but they last longer and parts are available.
Vito
Once upon a time the senco compressors were a rebranded rolair. They are good units. My old one had a kawasaki engine which lasted many years. I still have it but the pump and motor have been replaced. I always preferred the ones that had an air piston to control the throtle because they are less trouble than the cable operated ones. In most areas they are available from hungry framers that are out of work for under 500 bucks in pretty good shape. Check craigs list.
we have an emglo that we've done nothing to except add oil and gas. well we did replace the gas tank after something fell on it. Its about 20 years old now. I think essentially most compressors are semi-simple in nature and many work the same way. As long as it has a honda 5.5 it will run just about for forever, regardless of compressor brand.
