Bigh429
The sediment bulb is seeping around the threads. Anyone know a good compound or something to use. I tried Teflon tape, guess that is only good for air and water!
I use Teflon all the time, what I like best about it is if the base can't be tightened enough in the right spot, I just put a few more wraps of it and it tightens where it needs to be. Tank could also be leaking around the base where it is soldered to the tank.
This is what I use
