Gas pump didn't shut off
37chief
Location
California
I was filling a couple 5 gal cans for my truck. I pulled out the nozzle it didn't shut off. With gas squirting out of the nozzle I stuck it in my truck. I go into the attendant, she didn't have any idea what to do. I go back to my truck waiting for the tank to fill and start spilling out. I pinched the hose, and it stopped. Another guy pulled up. I told him the pump didn't shut off. He paid no attention to what I had just said. After filling his car he said the nozzle didn't shut off.To help him out I pinched the hose this time it still kept filling. About that time I left to kept from being roasted. Some how the attendant got it shut off as I was leaving. Ever had that happen? Stan
Never seen it happen, but I guess it would be wise to look for the shutoff switch on the building when stopping at a gas station.
(quoted from post at 14:39:13 04/23/19) Never seen it happen, but I guess it would be wise to look for the shutoff switch on the building when stopping at a gas station.
Yep, sounds like a good plan!
I'm confused. Did the auto shutoff not work or did the nozzle not shut off when you released the handle? This was at a gas station I presume. How were you able to pinch the hose? Those thing will stand up to a car driving over them.
No, never had one that would not shut off when the lever was released.
I've had lots of them fail to stop when the tank was full, but it would always stop once the lock was released and the lever went down.
All the gas stations I've seen lately had an emergency stop button somewhere near the pumps.
Never had to use it, but this makes me want to be more aware of where it is, just in case!
So the automatic cut off did not work.
Gas still flowed even when the handle was reset manually.
Gas still flowed when the pump was shut down via the on off handle on the pump.
And no one even the attendant thought to hit the emergency stop button.
Then on top of that the attendant allowed someone else to use this same pump.
Boy is that a one in a million chain of events.
(quoted from post at 16:25:46 04/23/19) So the automatic cut off did not work.
his sounds like operator error, " I pulled out the nozzle it didn't shut off.". Nozzle senses pressure due to level filling to end of nozzle, so if simply pulled from can, it has no way to sense level and shut off. So, it keeps flowing until operator takes action to stop it.
If the Blue Rhino cage isn?t in front of it. Or you could just drive through the wall like Jack?s in EV.....poor minnows.
MN requires all gas stations to have an emergency shut of accessible to customers at all times, I would think CA would be just as safe! I wonder if the pump would of shut off when it reached the credit card limit, it used to be $75 the last time gas got expensive, looks like it's going to be up there again soon!
Could you have forgotten to squeeze the handle to release the nozzle lock and shut off the pump before removing the nozzle?
Get on You Tube, type in gas station mishaps or something to that order. Most of the mishaps are people driving away with the nozzle still in the car but there are some other strange happenings to be seen. Like the person who used a cigarette lighter for light so see where the nozzle went in the car. I have had diesel nozzles not kick off here on the farm. Oops, maybe I shouldn't have said that.
I thing those attendants should get safety course before being hired! should be a red button you hit to disable the pumps, plus something inside. most customers don't know this.
Just hang the nozzle back up, that should shut it off, next go for the emergency kill button, they should be located near the entry/exit doors of the building and clearly labeled.
Could it have been related to the vapor recovery system required on CA pumps? At least once or twice I've had the recovery system suck up overflowing fuel when the handle didn't trip. And I've had malfunctioning nozzles on regular pumps fail to trip, causing gas to overflow, but they've always quit when I released the lever.
If the gas pump hose was that soft flexible it was ready to blow and should have been replaced long ago. If a station did maintainence like that I would not go back to them. They are just waiting on a big fire to happen and kill someone, I think you need to contact the safty department of the state that investigates the stations to give then their licence to operate. A good hose you could NEVER bend like that.
