Mike(NEOhio)
- Location
- Newbury, Ohio
My fuel supplier's new policy it no orders for less than 200 gallons and my tank is 175. Just got a deal on a 50 gallon TSC transfer tank and an unused 12v pump. Going to place it in the stand under the gravity tank so I can get the 200 gallons. I can fill the Oliver only when the old tank is above half due to the height so when it's too low I'll run it into the 50 gallon and use the pump. The tank was used some but the pump never set up. It needs a pickup tube and I'm wondering what to use. Just a piece of pipe? Will it need a strainer or valve at the bottom? Filter in the line? Is there some kind of power converter that will work of 120v from a nearby building or should I just use a battery and keep it charged. Some of my tractors are 6v so using the tractor battery is a no-go. Any ideas welcome.
