E R
I have A 1953 old Ford car been setting up for A long time. When he park it, it was running good.
Now I got it running. I put A small gas tank under the hood & to the fuel pump.
Now it will run.
I pull the old gas tank out, it is no good.
I can buy A used tank at wrecking yard with fuel sender gauge in it. It will be 12 vote.
My old car is 6 vote.
Anyone know if there is some way I could make the 12 v fuel sender gauge work on my 6 v. car.
The fuel gauge on the dash in the car I think is good. It is the sender in the tank that I am talking about.
The tank has a resistor in it that determines the level of fuel by changing OHMS as a float rises. It will work, but not be correct. Probably read 50% of what is in the tank. The sender out of your tank might be able to be adapted. There are also reproduction senders available. JimN
Go to your local napa parts store and ask them for a voltage reducer. It's about the diameter of a quarter and about as thick as cookie. That will drop the volts (votes as you call it)
John, with respect, the sending unit is a variable ground. It does not know if it is 12v or 6v. In the new tank it is a resistor designed for 12v application. it is a differing resistance curve. Thus it needs to be less resistance over a wide range. A new unit is the only solution. JimN
I think I will try the voltage reducer .That should work.If it don t work, I may have to go to the new unit.
Thanks A lot for the info.
