Gasket for pto housing
Axell
Location
Scandinavia
Hi
Looks like the gasket (e1adkn7299) on my super major for the pto housing where the lever is attached isn't oil tight. A new one could be nice to try. Can't find a made one so want to make one myself. Want to order a sheet before taking it off.
What is the original material? Is it cork, rubber or paper and what is the thickness?
This post was edited by Axell on 04/25/2023 at 07:29 am.
Are you referring to the square gasket, down on the side of the pto housing, where the shift shaft goes into the shift fork? If so, here is
the CNH number E1ADKN77013. Just as a side point, the thickness isn't critical. I have scraped off many damaged gaskets, cleaned the
surfaced, and used non hardening Permatex, out in the field.
