kentucky gardener
has anybody ever made there own gaskets. if so what material do I use. I'm making one for a case IH 252 compact tractor has a bad gasket in the injection pump some where.
kg
kg
There must have been some of you guys that were in the Navy and had to make your own gaskets.I was a machinist mate in the Navy. We rebuilt a lot of stuff in A division. If you needed a new gasket you would run over to the boiler room and they would give you a 36" or 48" roll of gasket material. We didn't have any fancy hole punches or the like. The tool we used for making gaskets was a ball peen hammer. What, you say? How do you make a gasket with a hammer. Well, say your making a gasket for a 12" pipe flange. You ruff cut the material to fit the flange, like maybe a 13" square. Then you lay that over the flange. Take your ball peen hammer and tap with the ball over one of the bolt holes until you could pull the slug out. Stick a bolt in there to hold the gasket in place and do a bolt holes on the opposite side and stick a bolt in that. Now that the gasket material is secure, punch out the rest of the bolt hole and stick bolts in them. Now you can punch out the big center of the gasket using the flat face of the hammer. It's quite simple once you've done a few.
Yes! Ron MNThere must have been some of you guys that were in the Navy and had to make your own gaskets.
You seem to be giving incorrect information on your tractor model number. I think you might be seeing the number of the front end loader attachment and mistaking it for the tractor model number. And describing the point of the fuel leak on the injection pump as “somewhere” will not prompt me to blatantly suggest what kind of gasket material you should make the gaskets to repair the leak from. More often than not injection pumps are sealed with o-rings or specifically shaped rubber gaskets that fit in grooves and allow the injection pump parts to fit closely to provide proper tolerances and clearance.case IH 252 compact tractor has a bad gasket in the injection pump some where.
I have been making my gaskets for years. Now with the price and availability of gaskets I’m glad I saved money. But of course some gaskets you have to buy. As an example I don’t buy thermostat gaskets or other simple gaskets. I buy gasket material in sheets or in a roll. Different thicknesses of course also.has anybody ever made there own gaskets. if so what material do I use. I'm making one for a case IH 252 compact tractor has a bad gasket in the injection pump some where.
kg
Ask OLD , be brags about everything he has done in the navy. Lol !There must have been some of you guys that were in the Navy and had to make your own gaskets.
Common on cars/trucks too. I have a couple of tiny ball peens that are probably 80-100 years old and have been dedicated to that as long as I can remember. got 'em from Dad. Seen and made lots of rear end housing, thermostat, carb base and other miscellaneous gasket with them
Or maybe a 255 tractor?You seem to be giving incorrect information on your tractor model number. I think you might be seeing the number of the front end loader attachment and mistaking it for the tractor model number. And describing the point of the fuel leak on the injection pump as “somewhere” will not prompt me to blatantly suggest what kind of gasket material you should make the gaskets to repair the leak from. More often than not injection pumps are sealed with o-rings or specifically shaped rubber gaskets that fit in grooves and allow the injection pump parts to fit closely to provide proper tolerances and clearance.
Look over the tractor and see if it has a model decal right on the hood or look around for a rectangular metal ID plate about 2 1/2 inches high and 4 plus inches long.
Try to narrow down the location of the leak and post a photo of it.
Sorry, I did not realize that telling my story of making my own gaskets in the Navy was Bragging.I have been making my gaskets for years. Now with the price and availability of gaskets I’m glad I saved money. But of course some gaskets you have to buy. As an example I don’t buy thermostat gaskets or other simple gaskets. I buy gasket material in sheets or in a roll. Different thicknesses of course also.
Sorry, but I don't think you should be into an injection pump and making gaskets for it.
I didn’t say that , I said old is always bragging what he did in the navy. I’m on your side.Sorry, I did not realize that telling my story of making my own gaskets in the Navy was Bragging.
I meant my uncle was in it I’m just finding out what material he needsSorry, but I don't think you should be into an injection pump and making gaskets for it.
He said: "I'm making one for a case IH 252 compact tractor has a bad gasket in the injection pump some where."What's wrong with him making a gasket vs a chinese shop making a gasket?
