Gassing gohpers
motorstuff52
The pocket gophers are digging up our farmyard worse than usual.
I am thinking about using a flexible metal exhaust pipe on the 8N to gas the gophers with carbon monoxide.
Has anyone had any luck doing this? I am also concerned if it will hurt the tractor. Will the back pressure hurt the valves?
Mike
Its done all the time here. Works well. I have also had them in hay fields. I hook up a tank type NH3 applicator and make a couple of passes thru the area. Gets rid on them asap.
(quoted from post at 14:15:41 11/08/18) Its done all the time here. Works well. I have also had them in hay fields. I hook up a tank type NH3 applicator and make a couple of passes thru the area. Gets rid on them asap.
!@#$ pocket gophers are a plague around here. Can you tell more about how you apply the NH3? Does it hurt what's growing there?
I've pretty much quit gassing gophers with my TO30 Frerguson.....because I can't find any. It has taken about 3 years of gassing and I still get perhaps one or 2 per year on 230 acres.
gassing
I read about using NH3 and was thinking any gas that is heavier than air would probably work . Propane is inexpensive and easily obtainable . No need to mix with oxygen and ignite it . I have armadillos holes that are bigger problems for me . I found this on a web search ,
[i:8a89b071d2] I use a 25-lb. propane tank, running a rubber hose between the tank and a 2 to 3 ft. long piece of 1/4-in. dia. pipe. I find the gopher run and put the pipe down into it. Then I turn the tank upside down to force the liquid propane down into the run. A cupfull will do the job since one cupful expands 250 times when it turns to gas.[/i:8a89b071d2]
(quoted from post at 19:00:54 11/09/18)
[i:dc996c3994] I use a 25-lb. propane tank, running a rubber hose between the tank and a 2 to 3 ft. long piece of 1/4-in. dia. pipe. I find the gopher run and put the pipe down into it. Then I turn the tank upside down to force the liquid propane down into the run. A cupfull will do the job since one cupful expands 250 times when it turns to gas.[/i:dc996c3994]
That has potential. Since they tend to plug the holes the gas would likely stay in the tunnels. Have you tried it?
(quoted from post at 07:05:57 11/10/18) What are you squirting in the carb to make the smoke?
Do the moles or gophers try and escape or do they stay in the hole?
I used a 50/50 mix of MMO and Seafoam
(quoted from post at 19:09:14 11/10/18)
[i:11aad955b4] I use a 25-lb. propane tank, running a rubber hose between the tank and a 2 to 3 ft. long piece of 1/4-in. dia. pipe. I find the gopher run and put the pipe down into it. Then I turn the tank upside down to force the liquid propane down into the run. A cupfull will do the job since one cupful expands 250 times when it turns to gas.[/i:11aad955b4]
I have not tried it . In the next few months I plan on filling in the 5 - 6 armadillo holes in the pasture . I plan on shooting some propane in and plugging the hole so my livestock does not break a leg .
If I keep the fields mowed the armadillos tend to dig in brush piles and other heavily covered areas . I may never know if the propane had any effect unless I find a fresh hole next spring .
