GBD fuel problems
WestTxMM
I've got a GBD that will run for about 5 minutes and then starve for fuel and die. Removed the hose from fuel talk and flows freely. Opened petcock drain under filters and it was under a vacuum. Final filters are new and primary strainer is ok. Is there a problem with the Bosch pump? Any ideas?
(quoted from post at 19:23:16 10/20/16) I've got a GBD that will run for about 5 minutes and then starve for fuel and die. Removed the hose from fuel talk and flows freely. Opened petcock drain under filters and it was under a vacuum. Final filters are new and primary strainer is ok. Is there a problem with the Bosch pump? Any ideas?
If it is like my G6, right before the filter housing there is a shutoff valve. The orifice is very small and may cause problem? You want to check if fuel is flowing freely out of the primary filter,.
