James Tabor
I recently purchased a 1945 Hand Start B Show quality tractor. Realizing it had been restored 4 years ago, stored in a climate controlled garage and not ran enough to burn the paint off of the manifold I decided to change all the fluids. I removed both the transmission and rear end drain plugs and left them out for 24 hours. I noticed that the gear oil was brown like coffee with lots of cream. There are no water leaks anywhere and the tractor still remains in a climate controlled atmosphere. I installed new Shell 80W-90 gear oil that had that transparent oil look like I am used to. After filling, I drove the tractor for about 10 minutes, rechecked the fluid level and noticed it had turned the same coffe and cream brown. What's up? Is it just due to airation? None of my other tractors (1947 H Farmall, 2005 JD 5105) do this. I let the old oil set for a few days to see if any water would seperate from the oil but nothing happened. Is this normal? Thanks.
