Gear shift start switch
SKYLER53
May need to replace gear shift start switch. Does the gear shift just come up with top plate? Is the switch hard to put in and adjust? It is for a TO20. Thanks
The switch comes off with 2 bolts, if you need to adjust it the 4 bolts on the plate do that. The switch is where the battery/starter wires attatch, not under the shifter.
Tom
Heres a pics
I could not start with the gearshift for some time(TO-30). Tried replacing the starter switch, nothing. Jumped the terminals and the engine cranked. I wound up tacking a washer to the starter switch so the shifter could contact the switch.
