gear shifter
Dallerd
does anybody know how to remove the gear shifter? farmall 544 tractor, it was stuck in 3rd gear. the rod doesnt want to release
The rod doesn't move either way with the shifter or without. I removed all linkages but the rod won't budge. The dealership says there might be a pin.
Yeah I'm not sure but I'm thinking there's a roll pin somewhere on shaft farthest left if your sitting in the seat. Cause the transmission is ok I got all linkages disconnected, and put each one in neutral. So the rod is binding somewhere in the housing.
Thank you! I found the actual rod has 2 pins in there. I just gotta pop those pins out and it should come out. Thanks
