Gehl 4600 skid steer , driven one side only
butchfig8
Gehl HL4600 skid steer , Got running after sitting a couple years, right wheels are not powering up, does a lot of circles
Anybody have info on who makes the pumps, motors and controls for this unit.
If its anything like a 4400 there are a few things to check. One is the linkage. One linkage for each side. The other is the tow valves on top of the hydraulic pump/control unit. There is one for each side. I do not recall right off the top of my head, but both should be orientated the same way. They release pressure on the drive motors. The other is to open up the reservoirs and see if the main drive chain has pop off. There should be two bolts on top that you loosen to slide the cover over to remove it. You will see a three sprocket and chain setup. The large sprocket goes down to the drive motor. The smaller sprockets go to each wheel.
Thanks for the input
Chains and linkage are connected, was never disassembled, I will look for the tow valves.
was thinking of swapping the hyd hoses to other side but have not a clue as to hyd flow paths.
