LDoyle
How / where would you check the output on a 51 6v generator ? I m guessing you can use a tester and just touch a post ( which one ) to see the output while running . My amp gage shows nothing , but I don t know if it s gage or generator.Thanks
" but I don t know if it s gage or generator."
What about the v/r? That could be bad.
Use the flow chart to troubleshoot the charging circuit.
75 Tips
Use a voltmeter to measure the voltage of the battery before you start the tractor. Start the tractor and measure the battery voltage again. If the charging system is working correctly then the battery voltage when running will be higher than when the tractor is not running. If not then you need to troubleshoot the system to determine which component is not working properly.
LD,
Have you ever known the generator to work and if so how far back? The generator may have to be polarized. As for the amp meter, is the circuit actually going through the meter? Check the battery with a voltmeter when running at a fair rpm to see if the voltage rises at all as suggested by one member.One more possibility is the relay may not be working. If it is the relay, buy a quality relay, not imported.
Hope this helps,
Mr. T. Minnesota
