bob from ill
just wondering what would need to be done if even possible to be able to convert from generator to single wire delco alternator. also remember its a positve ground system so it may not be able to be done at all.
(quoted from post at 14:09:02 08/14/09) Easy to do. Ground does need to be changed from + to - and to do that you switch wires on the battery and also on the coil and your done with the ground change
(quoted from post at 21:42:45 08/14/09) This is the Alternator I use.
Alternator
