Gene Bender
Oldiron29
Gene, Found a two way plow with all mounting hardware from farmall A would it work on an B or is the lift gang bracket 4" to short? I would think an BN would fit OK. your thoughts. Thanks oldiron29
The front mount for the B is different than from the A. The rear rockshaft would be wider for the B than for the A. Just too many brackets are different. Is the plow made for hand lift?
Gene, ya it was hand lift, I kind of new it was a long shot to many different brackets as you say. thanks
