Generator for W4
I have just purchased a 1945 McCormick W4
It is non electric but has a place for a Starter motor which I am going to put on.
I will also need a generator
Where does the Generator fit?
Will I need brackets to fit Generator?
Does the Generator for the W4 have a regulator mounted on the generator or does the regulator go somewhere else?
Is there a Cut out switch anywhere?
Would appreciate any help
A 45" W-4 would use the Delco 1101355 generator with the cut-out unit on top. This unit would use same mounts as an "H". The light switch would use the resistance unit built in.This switch has 4 positions(Clockwise)L(low charge)H (high charge)D (dim lights) H (bright lights),with the headlight fuse (SFE20) on the back of switch,with two resistance units,one for charging,one for lights.All but the housing for ammeter and light/charging switch are "H" parts.
