Given all the recent storms, power outages, hazards and life safety concerns, theres been lots of healthy chit chat and questions regarding the necessity, or lack thereof, regarding grounding of home backup generators, so I will take this opportunity to describe WHAT I BELIEVE the NEC has to say about it based on my recollection SO NO WARRANTY consult them not mePS our friend George goes to the head of the class as he has asked a lot of great and very relevant questions.
1) Iffffffff the genset is connected to the home distribution system via proper safe and permissible (NO suicide plugs) cords plugs and receptacles in which (very common) case the gensets Neutral and the homes Neutral are connected GROUNDING THE GENSET IS NOT REQUIRED and the Genset should be configured with a Floating Neutral. I believe the NEC allows supplementary grounding if one chooses...
2) Ifffffffffffff a portable genset is used to power cord connected tools via its onboard mounted receptacles GROUNDING THE GENSET IS NOT REQUIRED .
3) Ifffffffffff a construction site genset is used to power tools, again GROUNDING THE GENSET IS NOT REQUIRED and far as I know OSHA even discourages it.
4) Ifffffffffffffff a genset is used to power a SINGLE RV GROUNDING THE GENSET IS NOT REQUIRED..
5) Ifffffffffff a portable genset is used to power a home or cabin COMPLEYELY OFF GRID orrrrrrrrrrrr the home is grid fed HOWEVER theres NO connection of the genset Neutral to the Utility Neutral such as if the Transfer Switch has enough poles so the Neutral is SWITCHED (genset or utility feeds home) Thats considered a Separately Derived System and Generator Grounding IS INDEED REQUIREDSame as the homes electrical supply transformer, being another Separately Derived System requires grounding.
FYI 1 Some gensets (some smaller) come from the factory with a Floating Neutral, others (some larger) with a Bonded Neutral .. .
FYI 2 Purposes of Grounding are for protection against lightning strikes and surges and to maintain the grid at a common low voltage reference.. Mother Earth ..
FYI 3 Grounding in the above sense means connection to a proper approved GROUNDING ..
ELECTRODE of which a MADE ELECTRODE like a rod driven into earth certainly suffices and is the more common..
DISCLAIMERS again DO NOT take my word for this consult the NEC. Of course a person has the free choice to wire or ground a genset however he pleases, , to ignore or adopt any NEC guidelines, as its HIS risk HIS choice, you get NO argument from me..Im ONLY trying to help .
NOTE: If you dont understand the electrical theory or why any of these rules exist study up on the subject. I do understand them but theres absolutely no way I can explain it here in a few sentences. THIS IS ONLY MY PROFESSIONAL ALBEIT LONG RETIRED OPINION, but regardless, yall try to be safe out there and where life and fire safety of your family is in doubt at least consider consulting trained professionals and the NEC. .. Im pretty sure the above is correct BUT AGAIN NO WARRANTY its been a while lol if other professional electricians or power engineers can add to this or cite actual NEC references in support of or opposition to any of this, please do Im always willing to learn..
Best wishes to everyone here, God Bless and keep you safe
John T
John T
