generator is charging.
rustred
checked to see if it was charging this morning, and it was a yes, from original generator and regulator.
(quoted from post at 20:27:33 05/22/23) checked to see if it was charging this morning, and it was a yes, from original generator and regulator.
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto155129.jpg>
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto155130.jpg>
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto155131.jpg>
hat is great & I am lucky enough to have a 1954 Farmall , all original , that still works, too, for a voltmeter, your device is fine, but don't believe a word it says as a battery load tester. It loads at 17 amps and a starter load will be closer to 300amps and a "real load tester" will draw 400 amps.
i been using it for years and it works just fine. it takes more than 17 amps to turn that stove element red in it. i use it for load testing
batteries.
(quoted from post at 10:49:06 05/23/23) i been using it for years and it works just fine. it takes more than 17 amps to turn that stove element red in it. i use it for load testing
batteries.
t is fine if you only want a tiny load test.
batteries.
