Generator Issues
Happ
Hoping one of you guys can help me troubleshoot here. I have a JD 420 crawler, original 6 volt +ground setup. Had generator reworked last year, was charging great. Recently it will not charge, if I rev the engine way up it will kick in for a few seconds and then cut out again. Is it in the generator or a short or bad ground? I don't know and it's making me crazy. Have an OC-6 diesel with 12 volt +ground generator also started doing the same thing. Thanks
Your questions kind of wide open so here is a URL Link for my genreic non charging Troubleshooting Procedure. Para 5 will tell how to determine if non charging is a Genny versus a Voltage Regulator or cutout type of problem.
http://www.ytmag.com/cgi-bin/viewit.cgi?bd=farmall&th=665110
John T
John Ts Troubleshooting Procedure
Probably the voltage regulator if the generator is ok.Make sure you get the right one 6 volt,positive ground.Buy one from a reputable generator shop,some of those cheap off brands that parts guys sell don't work very well.
sounds like the regulator is going bad. You said it charges a little then quits. That tells me the generator is cabable of charging but it's getting shut down some where which would most likely be the regulator or a bad ground. Make sure the generator, regulator and battery all have a good ground.
Thanks, John! I think I may have printed that out when you first posted it, but if so, now I have two! Great to get all the troubleshooting tests in one place.
