ust use the whole furnace...already has blower and add more elements before or after blower, in space where the evaporator was located.(quoted from post at 09:24:44 03/22/23) Thanks for the kind words, hey I try my best to help and enjoy doing so.......
You state:
One would think a 2500-watt generator, which provides about the same wattage as a 20 circuit could easily start a small compressor. But I never got it to work.
NO SURPRISE, Thats EXACTLY what I was talking about. Still a resistive furnace heat strip provides a cheap n easy RESISTIVE load.
John T
(quoted from post at 08:54:25 03/22/23) It's amazing how true your comments are. I think the inductive load of the motor may cause the voltage to lag behind the current reducing the available power. A number of years back I was using a 120-volt 2500-watt generator to run the block heater in my 4020, 2000 watt. I wanted to have a small air compressor at the barn just to pump up low tires. I put the smallest drive pully that would work on the motor of a small compressor and still no dice. One would think a 2500-watt generator, which provides about the same wattage as a 20 circuit could easily start a small compressor. But I never got it to work.
