On this forum from time to time, we attempt to diagnose issues with generators. Sometimes without success. I acquired a 7500-watt Generic portable generator on an on-line auction. Someone and been working on the carb, not a good sign. After I removed and cleaned the carb it would start and run but only for about 30 seconds like it was running out of fuel. I pulled the air cleaner back off and mounted the carb without the air box, and it continued to act in the same manner. The motor was a B&S IC with an oil filter and a pump. I took the bowl off the carb and turned on the fuel and I got good flow. I then disconnected the oil shut off system and the generator ran perfect. I then tested the oil pressure shut-off switch, and it still shown it was grounded with the generator running. I removed the switch and installed an oil gauge; the motor had 20 pounds oil pressure. A new switch is on the way. Evidently the oil pressure shut off system has a timer which allows the motor to start and run a short period before engaging the system. The power head on the generator has power.
