GMT
just got a 1953 Ford NAA - installed a new battery and started it. When we shut it off the generator kept runner like a motor. I could stop it be putting my boot on it but when I backed off it would keep running.
Final disconnected the main wire and it stopped
Any suggestions?
The cut out is stuck/bad. Your tractor could have one of two types on it. The most common, original, just has two terminals on it. They are opposite each other. This one just cut out when the voltage got high enough. It also is supposed to disconnect when not charging, generator stopped. The contacts burn together and stick. The more modern type actually is a voltage regulator. They usually had three terminals, marked: Field,Gen,and Bat.
They both cost about the same money to replace. The only problem is that most are imported anymore and about half of them are junk. This is even true if you go to Ford to buy them. This site has them for sale as well. I think that these are Tisco parts. They are imported too. I can"t/won"t say how good they are.
You should try posting over on the Ford forum. They can better tell you where to get a good one. I have repaired them years ago by cleaning the stuck contacts. I would not recommend it anymore. As the one on it is more than likely a replacement. I only had any luck with the old originals, they where made better.
The Cutout Relay, regardless if its part of a full fledged 3 or 4 terminal Voltage Regulator or a simpler 2 terminal (BAT & GEN) Cutout Relay alone, is supposed to OPEN when the tractor is shut down so the genny gets disconnected (relay is supposed to unlatch and open) from the battery and doesnt run like the DC motor it is.
When this happens if you remove the wire off the BAT or GEN terminals and the genny stops motoring, the cutout relay is unfortunately sticking closed perhaps due to the contacts burning/welding together or some other electrical problem. One can seperate the contacts and clean/file/buff them but once the shiny silvery coating is removed that can stick again.
This has to be fixed or else the battery totally discharges and the genny gets hot. If you get a new one be sure its suitable for your ground i.e. Pos or Neg ground, and that it has a good electrical frame ground connection.
John T
You're darned lucky the belt was loose enough so it COULD keep running. I burned the wiring right out of an Oliver 77 one time when the regulator stuck like that.
Repair / replace the regulator / cutout.
BEFORE you start the tractor, make sure you have the new battery connected correctly to ground and polorize the generator.
If the battery is installed with opposite polarity to the generator, it will cause a dead short between the generator and battery which will instantly weld the cutout contacts together.
