genesis hydraulic problems
so i hooked the discbine up to the 8970 today and the swing works fine but it will only lift if i swing it at the same time or pull another hydraulic lever. any ideas????
You have a bad shuttle check valve in the valve that will not lift.
I don't want to suggest where to look in that particular valve stack other than to say that there is a shuttle check in the load sense circuit of every spool.
Probably best to take a quick look in NH parts online to ID the 'shuttle check valve' so you know what you're looking at, then pull it out. Might just be some dirt...
Could also be a crack in the seat or some such odd thing.
Rod
Shuttle checks are located in the front side (towards cab) of each remote valve slice. Someone probably will post that they can be accessed without disassembling the stack, but I can't. Replace with updated seats with backup washers against the o-rings. Might as well update all valve slices AND the 3pt valve slice while you are at it. Not many $$, just the valve seats, a bushel basket of o-rings, and some time. A good excuse to buy that service manual that will answer the rest of the questions you have.
it's the bottom ( number 1) valve.. how much do you have to take apart to get to it? i tried it in all the valves and still doesn't lift. the lift circuit on the discbine only has one hose, does that have anything to do with it?
Try replacing the male tip on the lift cyl hose first. My other post has the answer to the 'how much do I have to take apart' question. The valve slices come off the stack. Single acting cylinder shouldn't matter.
i replaced the tip but didn't make a differnce. decided to let the dealer ffix it. i've never been good with hydraulic stuff. is there a pto brake adjustment on these tractors. sorry i ask a lot of questions but i like to find out everything i can.
There are test ports on the rear for PTO clutch and brake pressure. They should both be checked prior to any other repair. That said, you probably have a broken PTO brake band. That can be replaced on an 8970 with less time & effort than it will take to replace all the shuttle checks in the HPL and remote valve slices. There is an outside chance that your PTO valve housing is cracked. That is a little more labor and some more $$ for parts.
