Geo-TH,In/terramite
bweb
George have you ever had one of your terramites break down to where you had to pull them back to the shed to work on? I have a TC5 that
hasn't ever died out in the field but I was wondering what the correct procedure is for pulling it without the engine running.
Thanks, Barry
I haven't had to tow a terramite, knock on wood.
In the neutral position the transmission is the brake.
I would try pushing on the forward or reverse peddle and see which works best.
Just an idea. Stop terramite on a hill, turn the engine off and see if pushing on the forward pedal doesn't allow it to roll down the hill.
(quoted from post at 14:30:07 10/24/22) I haven't had to tow a terramite, knock on wood.
"I would try pushing on the forward or reverse peddle and see which works best."
As I recall, they have a little hydrostatic transmission, if that is TRUE that would be really BAD advice.
IF there is a release on the hydro to allow it to be moved while the engine isn't running moving/towing it SLOWLY for more than a few yards will kill the hydro due to luck of the lube from the charge pump running.
Do you have the operators manual? There should be a valve on the transmission that you can turn by hand to allow you to bypass oil to tow the terramite???
I have a manual, nothing in it about towing and no levers on transmission.
I would use my other terramite or my Kubota, lift one rear wheel and pull it backwards
I think it would be best to get it on some sort of stone boat /trailer or other device to pull one with the hydrostat if you still want it to work afterwards. To push it with tires skidding for a few seet is one thing dragging it to get to the house from the back forty would be an entirely different thing.
