Getting ready for winter!cheap plow for loader tractor!
I am sure a lot of you fellows have used a setup like this,but I am posting this hoping it will be of some help to somebody in this same spot.
I bought this old 7.5 foot truck plow for $100,to use on my mf203 loader tractor,because my cub 184 that I use for snow plowing finally blew up.
Anyways,this is cheap,simple and very durable.Altogether cost me $160 after the needed steel.3/4 ID steel pipe,3/4 round stock,a shackle,a fee cutter pins,and a heavy T_post which I had already.pictures below(sorry,do not know why my 8n is in there.
Rock
I have no idea what is going on with these pictures.I had all of them on the original post,then nothing appeard,tried it again and just a random picture .let's see if this works.
Rock
You should be able to make a seriously high mountain of snow with that set up lol. Will be curious to know if when using blade at an angle if the leverage of the blade so far out front pushes the back end around on you.
Yes,I plan to get that working soon.The nice part is the plow has manual angle as well,so it can still be used until then.thank you for your interest.
Rock
I also use a truck snow plow blade for snow removal, I made brackets and welded them on blade and then remove loader bucket and bolt the blade on the loader arms with a brace mounted and then bolted to the loader frame.
Big problem I see is the keeping of the loader frame ends down to a level that will not try to dig in or push loader up when using on unlevel ground.
A lot of guys use pick-up plows on tractors but they mount them in the bucket. Just weld a couple tabs on the floor.
