I have a Gleaner E with factory cab and blower system on the back for side hill use to keep the grain from piling to one side.(I assume as I know nothing). How many years did they make the plain Gleaner E and about what year would mine be?
I have a Parts combine bought new in 1964 and I been taking parts off it to fix the Feeder Beater. I notice the Newer combine broke the shaft where the sprocket pins on the Feeder Beater and the 1964 model had a slip clutch on the Feeder Beater. Also the 1964 had 3/8 bolts to mount the roller and the later model went to 5/16 bolts but the plate has holes for both. They were definitly making the later machines cheaper???
Both Maachines are pretty well wore out and I need all the rubber bearings where the pins slide in and out. Any source for these any more? Since the cCombine will see little use anymore I may have to make some out of rubber or plastic.Cleddy
