Jddude
Getting ready to run beans with my e3... Changed out sprocket On cylinder to a 42 tooth and I think she is ready to go but just wanna make shure there isn't something else I need to do or watch out for... Thanks in advance
I run a 35 tooth so with a 42 tooth you'll probably be more in the middle to top half of the hand crank variable speed cylinder adjustment.
I'd start about 1/4 on the cylinder and if you have green stems not processing well you'll want to close it down from there to crunch them up. I run 3 bars on 1 (rock door), 3 & 5 positions. I put a half round bar on the door last year instead of channel concave to supposedly reduce splits but not sure I saw that much difference. I run my chaffer & sieve at factory suggestions but pretty much turn the air all the way up on both fans.
Good luck! Mike
