gleaner engine in WD
Nothing to just put it in. The governors are different. Look at them close,with both engines out. You will see the differences. Can change whole front cover. Or just change gov linkage. Seems like you need to put a bushing in the combine front cover. Also the carburetor is pointing to the front. Can just turn it around. Combine carb throttle shaft is adjustable. Water pump on combine is to long. Use your tractor pump. All I can think of now. Vic
