Gleaner K Power Steering
Alan V
I posted this question on the Combines board, but got no response. My problem is that I'm trying to remove the power steering hydraulic cylinder on my Gleaner K combine so that I can rebuild it (leaks badly). But I'm having trouble removing the pins on the clevis ends. I have a parts manual, but it's not very clear on what kind of pin this actually is. I tried pushing it out with hammer and punch, but it will not budge. Is there some trick to removing these pins?
Not sure if this could be your problem but I'll pass it along just in case it helps. Had a pin that would not come out like yours. Finally realized that it was so worn that it made an offset in the pin that basically locked it in place...had a shoulder on the pin that would not let me drive it out. Solution was to get the pin centered on both the outside and inside holes. Hope that you can understand what I'm trying to say. Den
