The other day I had to start the tractor with either because it was cold out. On the can it says not to use it on an engine with glow plugs. I would like to setup the tractor so it is easy to start even when its cold. I ordered a manifold glow plug from yesterdays tractor. I have never installed one and it did not come with any instructions. I am assuming I have to drill and tap a hole in the intake manifold to mount it. Wondering about the connection to they ignition. Also the connection to the fuel. Where do I connect that fuel line and what connection do I use on they ignition for the electrical. Last question because I will have no light can I cheaply connect one (installed the instrument cluster from YT also) or should I just wait X amount of seconds first. I also purchased the ignition from yesterdays tractor.
