Glowing hot manifold
I have a 48 A which is having some issues. The manifold will get cherry red after a short while in non-working mode. Running rough, and backfiring. I cleaned the carburetor and drilled out the three idle passageways. What else could it be?
Something is still plugged, sure sounds like it is running lean,check fuel flow to carb,then out of carb drain,if all good,pull the carb again. you didnt say how idle and or load needles affect it,should be able to make it run rich and black smoke out the exhaust
Double check your timing. Broke the impulse spring in the mag on my G once and it was very similar symptoms.
