golden jubilee
Would you believe that the shop service manual, aftermarket fo-19 I&T manual, and the owners manual all cover the hyd crontrolls.
What problems are you having, and do you still have the squarish vane pump.. or the more cylindrical piston pump. no variable adjuster on the piston pump.. etc..
soundguy
My brother-n-law had problems with his he removed pump had rebuilt . The guy that rebuilt pump said it looked OK but he put new seals in . When he started to install pump he found Gaskets were bad on the conections to pump . The problem to start with was the pump would loose prime and not pump all the time .
