Good Riding Mower
Steve@Advance
Any recommendations for a small residential duty riding mower? Not a zero turn, but a regular steering wheel type. This would be a new mower, not a restoration or older model.
Someone was asking me today, I suggested finding something with a forged steel or cast front axle instead of the spot welded sheet metal type.
Are there any that have a good front suspension and steering?
Thanks!
I highly recommend AYP machines. American Yard Products. They make Husqvarna, the large Sears machines and several others. Both of mine have cast fronts and I have ball bearings in my front wheels. Nice tuff machines. Go on Ebay. There are a lot of dealers who give some REALLY good deals on these machines. Tennessee, north Carolina, etc. Some even include shipping. Well worth looking. One hint...you want the machines with the bigger 24 or 26 x10.5x12 rear wheels. These will have the heavy duty rear ends. Also you want the 26hp twin V Briggs engines. If you can go talk to a dealer. There are a fleet of options on these machines. Personally I do NOT like the Kohler engines. Simplicity is super duper but you are talking very big bucks. More of a status symbol.
What price range? What deck size? I agree with Jeffcat on Husqvarna which is owned by Electrolux. "Eletrolux owns Husqvarna, AYP, Partner, Poulan, WeedEater". They also make some of the Craftsman mowers. Is there a good servicing dealer around? I know there are some higher priced mowers with power steering.
Now prepare for 200 responses saying that green brand
I have been riding a Sears Craftsman 2 since 1989. 18hp 48in deck. engine still strong, deck still good, never have checked oil in rear end. no leaks so why check ? has mown my two acres and countless acres of Little League fields.
it is now my backup machine.
made by AYP.
I have a Husqvarna 2 blade 46" Hydrostat (only way to go on a lawn mower of the type) for my conventional which is my wet weather mower, big box version. I like it because it will cut wet grass and is hard to clog up due to the 2 rather than 3 blades and sweeping, tall, stamped steel discharge area.
When I bought it it had a Kohler Courage single 20 HP and when it vibrated itself to death, including cracking the main casting (made an X-Kohler buyer out of me), I replaced it with a 20 hp BS V twin which has been nice. Other modifications include soft seat springs (Troy #732-05182A...but Cub Cadet also uses them), replacing all 4 tires with soft sidewall 2 ply Snow Studded tires for traction on pond banks and soft ride, and a Bungie Cord on the rubber discharge chute to suspend it up off the ground for cleaner discharging.
At my coaching, neighbor bought a newer one with the 22 HP V twin Hydro (not using my mods) and it has way more power than you need.
The soft spot isn't really soft but you need to realize that the deck is attached to the main frame with welded brackets. If you go around banging into things, or slamming it against the bed of a P/U while loading with straight loading ramps....like another neighbor did with his, you will need to get out your welder....but that would be with any type mower of the sort.
Personally I prefer the stamped steel decks over the fabricated like my ZTs of different brands, even with three blades (retired L110 JD example) as the interiors are smooth, flowing surfaces and wet grass exits much easier without piling up, requiring me to jack up the mower and wash it out every time I use the mower (wet grass) which is a Pain for me, even with making and buying several "gadgets" supposedly to make the job easier, ramps, both built and bought and finally just getting out my 24 hp tractor/loader and a chain and raising it...in a different location each time to prevent the goo pile up.
I have and really like the John Deere's. The twin touch control hydrostatic drive is hard to beat. Also the Kawasaki engines are smooth running, quiet and long life. Note: the big box stores John Deere's are not the same machine that you get at the John Deere dealer.
My Grandfather bought a Husqvarna, and that?s the worst mower I?ve ever seen. The brakes had to be adjusted every couple months or they wouldn?t hold. The engine was always having problems, till it finally quit at 400 hours. So my Grandfather went and bought a John Deere D120. It?s hydrostatic drive, no power steering, but it steers easier than a car. That mower was only in the shop for oil change till it hit 425 hours, when the engine gave out ( which I was disappointed about), but even with that it was still better than the Husqvarna. So we put a new engine in the JD, and it?s still going today. Now my Grandparents mow about 4 acres, and that JD wasn?t designed for that. So it?s partly there falt for buying a mower that?s too small. My grandma on the other side of the family bought a JD D100. She only has 3/4 acres to mow. So in 9 years the mower only has 190 hours on it and still works great. That mower is a gear transmission, and I don?t like it as much for mowing, but I pulled some pretty heavy loads with it, and I still works.
I hope this helped you.
Do not buy based on brand.
It seems no brand builds all of the models offered with the brand.
I.e
Huskvarna might build several models, and MTD, etc. builds other Huskvarna branded models.
I have two John Deere riders, a 21 year old GT262 and an X320 which was my fathers. I do like the X320 hydrostatic drive for mowing . Craftsman is mentioned below and many of the larger Craftsman were well built machines but Sears appears to be on the way out so I don?t know that I would buy a new Craftsman as you might be on your own for warranty work. I would compare buying from a local dealer to the large retail store price, my neighbor bought a new Cub Cadet from the local dealer and they matched the price that TSC and Lowe?s or Home Depot had, plus free delivery. I would go with JD because we have a local dealer and I tend to keep things a long time so parts available is important.
I don't think there is much difference in brands,EXCEPT,for dealer backup in your area.Other than that it is like changing deck chairs on the Titanic.The big thing is to keep it
under cover.Not under a blue tarp in the yard.Humidity,rain,snow,sun,all seem to eat lawnmowers.I have a 73 Wheelhorse that has been here since new.It has been through a few new
decks,some rear hubs,(they loosen and wallow out)and a set of rear wheels.The tractor had hubcaps and held the wet grass in.Also a half dozen tie rods.The original 12 HP Kohler
engine has never once been apart.We think the carb has been replaced 4?maybe 5? times.The throttle shaft eggs the body out.It is starting to use oil now,about a cup in two
hours.We're thinking now it might make to 50 years before the engine has to be done or replaced.It has been under cover since day one,It is always started at the lowest RPM
possible,not raced up like so many people do,and is always idled a minute before shutting down.
simplicity/ferris has some models under complete suspension. had very good luck with unit I sold. I only have couple zero turn units left in my dealer close out. why are you totally against zero turn, no comparison if you have much trimming
I have two seasons on my Husqvarna, 24 HP Kohler, 48" deck, about 100 hours. Like it but I've modified the plastic chute for the clippings. It is angled downward at the exit and it leaves a thick strip of clippings that will not spread. I heated it and formed it so it's almost straight out. Blows the clippings higher so they spread out. The deck is hard to clean out, the hose connection is a nice idea but only gets the main areas. When cutting at the lower heights the edges of the deck will dig in. Next step is to shim the blade spindle down.
You did not say if it had to look like a miniature tractor. If you just want an inexpensive, reliable, bullet proof, lawn mower it is really hard to beat a Snapper rear engine rider. A proven design, 30 years old.
The highVac decks are really strong.
I have even used one to mow fence lines in pastures.
It really depends on how much you want to mow and the condition of the lawn.
I currently have a JD 140D, 3 blade 48? deck. Engine ( JD / BS)and hydrostatic are good but I?ve had problems with the spindles and deck cracking. I?ve replaced and repaired spindles but I mow some ground where it really shouldn?t go. On my lawn it does ok but will sometimes leave a space between the blades, so it?s important to keep them sharp and deck level. The wider deck can scalp the ground if it uneven.
I also have an old JD LT110 with a Koehler Command and it?s still going running and I use it in the tree field. It?s a 42? deck and gets between the rows easier. It is beat but still keeps going and does a good job.
My dad has an JD 300X and it?s a smother ride, heavier machine and has had a series of more costly repairs.
My other tree neighbour has a Huskavarna 42? mower. He paid as much as my JD and it is defiantly weaker frame and deck. Engine is OK (BS) but the belts are constantly breaking and it doesn?t do as good a job at mowing ... seems to always be scalping and can?t go high enough.
The best bang for the buck was the 42? Murray mower I bought a while back. It was average quality over all but it mowed well, parts were cheaper, and it also relatively cheap to buy.
Personally I will by at Home Depot of Lowe?s or Canadian Tire what is on sale and seems the best built. I consider them a tool. I push them as far as I can but also expect they are going to be replaced in 3-5 years.
I will stick with a 42? next time. I really don?t see the advantage of professional grade unless you are mowing every day. Remember it?s a lawn mower not a brush cutter.
Now you said you didn?t wan a zero turn so I don?t want want o get into that except that if you are willing to pay more, even the cheapest one will mow faster and as well or better as the typical lawn mower.
Good luck, Grant.
Forged axle is a must if you butt up the machine to any rocks . Once you weld the stamped axle{craftsman] it will keep splitting open and is not repairable.
About the only tractor style mowers I deal with are Husqvarna, John Deere and the various MTD/troybilt models. I work for a Husqvarna dealer.
1. STAY away from the plastic transmission models!!!! They are junk! They were junk! and I cannot keep them working smoothly and reliably. General transmission needs to go back to making washing machine transmissions.
2. Regardless of which brand you chose, keep the front axles greased. Husqvarnas tend to get a lot of slop in the steering and after a while develop a severe toe-out condition in their wheels. Then when you back up, the wheels go toe-in and it gets difficult to control the tractor in reverse.
Smaller Deere mowers from the box store have a similar setup, but I have only a seen two or three that had the toe-out problem.
3. MTD stuff was pretty much built to meet a price. They also own Toro, Bolens, Cub Cadet, White and some others. The late model Toro, Troybilt, and 1000 series Cub Cadets are practically identical and tend to have the same problems. Short belt life is one of them.
As far as the cast axle models go, The cheaper MTDs are the only ones I know of that still use a stamped and formed front axle. In the last 10 years I have not seen a broken stamped axle beam or a broken cast axle beam either for that matter. But in either case, if it is broken the owner is probably going to need a new front axle. I have seen some broken spindles, but they hit something hard or something else hit them hard for them to break. And I don't recall seeing either the stamped or cast axles even being bent in those cases.
Fortunately I've got a lifetime supply of Wheel Horses, that mower deck is 50 years old and the tractor has over 1900 hrs. This tractor and the one with the chrome are 31 years old.
How about an electric riding mower. You said it's for residential and the electric units will go a couple hours per charge. Have him check out a Ryobi RM480E or a Craftsman or a CC (everybody's jumping on the moving the air pollution to somebody else's back yard.)
BTW: Is the Raven hybrid still manufactured? I liked the idea of a mower/atv/portable generator.
15 years, 380 hours on the Original belt on my 1050 series three blade CC. I bought a new spare a year later and it is still hanging on the same nail in the shop 10 years later.
(quoted from post at 02:20:44 12/29/19) Any recommendations for a small residential duty riding mower? Not a zero turn, but a regular steering wheel type. This would be a new mower, not a restoration or older model.
Thanks!
Beware of the scrawny K46 transaxle in the low to mid level mowers .
In the JD line the X380 and up have a medium duty or transaxle .
Thanks!
Several years ago I bought a new Yard Machines, by MTD riding tractor mower from Walmart. Use it every year, never even had to change a belt on it. Good little mower tractor.
(quoted from post at 15:22:50 12/29/19)
Yikes! Who makes / sells lawn tractors with plastic transmissions?
The HST is the weak Link if you try to do anything with mower except mow.
A guy ruined his 25 hp hushy varnie in about 300 hrs pulling a trailer behind his.
My old JD garden tractor has an HST filter and a place to add and change HST oil.
I look for cast iron front axle and electric clutch for mower.
I have changing the 2 belt tranny type mowers.
I usually have to grow new skin if I don't wear gloves. Sometimes invent new words too.
The upside is you can repair the tranny better than you can a craftsman HST.
Some cheap JD
Have a single belt going to an actual gearbox in transaxle. They jurk when starting, but last longer.
I have all the mowers I talked about above. I love my 20 year old JD garden tractor the best for ride and durability. It also has tractor bar tires and a 30 inch tiller 48 inch mower.
George
You got that grease the front axle right! Trouble is neither of my Husqvarna tractors had one. My big baby GT-2254 Had that stupid plastic bushing and if it gets just a little wear on it the machine will not turn to the right. No how, no way. I installed a bronze bushing and cross drilled the retainer bolt. Nice 90? zirk fitting in the end. Another thing that helps a lot are those trust roller bearings between the axle and the spindles. You can steer with one finger when driving on the street or paved driveway. I think the ball type will work a little better. My dad's 41 Chevy pickup has them in the front end under the king pins. Keep them greased!!!
I bought a Gravely 8122 last Winter from an estate garage sale for $300,cleaned the carb,bought new battery mowed all Summer with no issues probably last for years.You might want to consider something like that over one of those junk low end mowers.
For a small yard I'd go with anything Murray or MTD - with any care they will last decades if all you do is mow a residential lawn. If you wanted something easy to work on - go with a Snapper. There is a reason they've been built the same for almost 50 years.
https://www.snapper.com/na/en_us/product-catalog/riding-mowers/classic-rear-engine-riding-lawn-mower.html
They are made to stand on end for easy service of the deck and blade, and the transmission is nearly fool proof.
