Good Stuff!!!!
super99
I was at Motion Industry a while back and saw this on the shelf. I asked the counter guy if it was any good. He said all of the local industries buy cases at a time,they say it’s the best they have found so far, so I bought a can. It’s kinda pricey but the couple things I have tried it on,I am impressed.
Best I've ever used. The old school dropper cans are cheaper than the aerosol. Still expensive, but worth it. My opinion.
I am the odd man out I don't care for it... I understand the principle on how it works I have played around with it. I have gave it years to work on a stuck part sometimes it did. I don't have the time to wait on it are anything else as far as that goes...
My go to... They foam up when it hits the part and sticks to it.
I had several cans of PB Blaster that the pressure was gone, but still had liquid inside. I got a clear plastic spray bottle, poured in some ATF, then punched holes in the PB and dumped it all in. Every so often I add whatever I can find, shake it up, works pretty well.
My Dad bought a can or two, tried it and became a dealer so he'd always have a can around. He gave me several cans over the years, I buy PB Blaster but it's not even in the same league. Once I get something apart I put it back together with a swipe on anti-seize so it comes apart easy next time.
Of the things I've tried, I liked it the best.
I've not tried the ATF/Acetone mixture, but have heard that was just or even more effective.
I have the carburetor off of a Oliver 88 that has set for several years that needs cleaned up. I took it apart and can blow air through all of the passage ways. The choke shaft is stuck. I have a crockpot that I can put it in and heat it up, what is the best to use to clean it up? I have heard vinegar, toilet bowl cleaner, purple power or I have a gallon of carburetor cleaner from Napa that I could just soak it for a couple of days. Which one to use????
It's called Kroil, and it's the best there is. It also comes in squirt cans. It will get just about anything loose, that has been rusted.
