Gooseneck cover
I'll jump on the bandwagon--don't drive it in the Iowa salt in the Winter--problem solved---Tee
That is exactly what I use, 40 x 60 pole barn Works perfect, also protects some hay and a couple of tractors.
Do you mean frame or deck? Tarping trailer usually bad for the frame, and if the tarp isn't perfectly water tight, bad for the deck too.
Undercoating/oiling trailers used in winter plus parking on a surface with no grass or inside is the way to go for frame protection.
