Got me a tractor !!
Anonymous-0
Bought a Case CK430 , loader , brand new bushhog 3 pt mower, bale spear, and rear tire chains . Motor is locked up on tractor. Got it all for $800 . Not sure whats wrong with it yet. Gonna haul it home thurs and let the fun begin ! There is a lever on the left hand side ,sticks up from trans . Is this high.low range , or forward rev shuttle ? Looks like it is gonna need rear tires soon too. Any good places to shop online ? Good bad points to these tractors, anything else I should check out on it ?
Thanks !
Don"t know a thing about those tractors, but sounds like just the eqmt is worth what you paid. Good Lord willing, the engine will only need something minor. Enjoy!
I'm guessing forward reverser shuttle lever?
But if it has a PTO, it could be the PTO lever.
On my 530 the shuttle is on the dash next to the steering wheel.
I have no pto on my 530.
Hope you don't have to get in to that transmission. It cost thousands to fix them.
What year and motor do you have?
Hope you have a Perkins in it?
Sounds like it has the optional hand cluch on the lef thand side. On the right side is a high/low lever or if equiped with triple-range then High/medium/low. if there is no lever on right side then it's just straight 4 speed. since it has hand cluch means it's not case-o-matic.
They are a good little tractor if treated right. Major problems are that an internal seal likes to leak on the three point piston which allows settling and also on the trans/hydraulic reservoir. The tractor can still be continued to run with those issues though without damage.
The engine should be a case 148 cu in. 4 cyl. if gas, 188 cu in. if diesel
Good luck
No ,it's not hand clutch, it has 3 positions. It has gas engine . no levers on right side. Thanks for info . I look forward to getting this to my shop and tearing into it.
The lever that sticks up on the left side is the shuttle clutch, it give you quick forward and reverse, with neutral in the center position. I have a 430 CK that I use more than any other tractor. I love it.
