johndeeregreen
C1 @ 2,000 rpms pressures is 170
C2 @ 2000 rpms pressure is 168
C3@ 2000 rpms pressure is 170
Lube pressure the only gauge I had went to 100 so the numbers aren't broke down the best. Rpm's were between 1000-1200 rpms to get 10psi, shifting through the gears the pressure dropped then quickly went back to within 1 psi of the original 10 psi
