So, I'm trying to figure why my '50s 8N is blowing blue smoke, tore it down did a dry comp test, showed 90psi on 3 & 85 on one. Took head off looked over valves, looks good there [will lap & add new seals while things are apart] Stopped at tractor shop and mechanic ask if I had the oil bath cleaner hooked up when I ran it and if I'd cleaned the inside good. It was hooked up & I didn't check for upper intake holes being clean. He said it could acctually suck the oil from the cleaner into the carb/head and make it smoke like crazy. Souns like I may have discovered my problem. Anybody experience this??
