jon f mn
Been bad weather here and I got called in to work to fill in for a couple days so haven't done much. But did spend some time on the 646 and got things working. Seems to run very well and works decent too.
The first thing I found was the points were stuck, had to free them up. They looked new, just were stuck open from sitting. Had to put a new float in the carb because it was stuck to the bottom of the bowl so hard it got destroyed trying to get it loose. The speed pedal was also stuck and needed to be freed up, as was the forward/reverse valve. I put in a new amp gage and fixed the wiring, and now it seems to work well. Will need new tires yet and the oil pressure light burned out and will need to be fixed yet. Soon as I started to use it the steering wheel broke too, guess thats going to be a challenge because they say they are unavailable. I do have an idea about fixing mine, we will see if its successful. Kinda anxious to use it now.
