governor gears
1948jr
I got governor gears and wts ,the shaft and thrust bearings .the whole works from a late model B to put in a 50 ,the main difference I see is the weights have 2 fingers instead of 1 . Will this work in a 50?
Makes no difference. Pin part numbers are the same so they will mount up. Don't mix them though as they will weigh different.
