governor swap Question
cjunrau
Is it possible to use a governor from a Versatile swather and put it on a Massey.
Is there anything that would cause it not to work.
If the bracketing ans alignment work, it will be OK. The active throw of the new governor arm must be the same as the old governor, the governed maximum speed will depend on the drive and driven pully ratio, and the setting/s inside to achieve the same High Idle. Good luck. Jim
Pretty general question I would think and maybe impossible to answer without knowing what kind of engines and models we're dealing with.
