Governor Troubleshooting
Colin King
I've been working on this 1950 side mount (12V) trying to diagnose low power and run time issues. Oil pressure is 25PSI cold, 10-15 hot idle. I have double checked point gap 0.025 and firing order.
Symptoms:
Tractor starts right up and when warmed up, idles very nicely. It throttles up well, and runs nicely at 2000-2100 RPM without a load on engine. But when throttling down, it won't return to idle, and will instead run at about 900-1100 RPM on the tack.
In terms of power under load, the engine will die if you use the brake to make a turn with engine in the 1000 RPM range in 3rd gear. In 4th gear, it barely has enough power to get up a small incline, even at 3/4 throttle. If you use the throttle to give the engine more power when the engine is under a load, it will not respond with more power. If the clutch is pressed after trying to put a load on engine, the engine races and will begin to hunt. If you try to idle down at this point, engine will continue racing for several seconds before it begins to slow down. It will not return to idle, but will run in the 1000 RPM range again.
Observations:
When engine fails to throttle down, I can push the throttle at the carb down to bring it back to an acceptable idle. It then idles very nicely. I've noticed that when using the throttle lever, the carb-to-governor arm seems to bind and will not return to the idle position, even if the throttle arm of the governor has returned to the idle position. Again, pushing the arm back returns engine to acceptable idle. I have checked and adjusted the linkage per the FO-4 manual. The governor spring also seems to fit snug without any up and down motion. There is nothing catching the carburetor linkage to cause it to bind.
Removing the governor, this wear pattern was in the housing:
I've never worked with a governor before, but the side to side motion of the governor shaft seemed pretty sloppy.
The wear on this ball is consistent across all three.
Based on the wear patterns and the symptoms I've described, do you think I'm on the right track? If i am on the right track, is this wear significant enough that the governor should be completely replaced or should I invest in a rebuild kit?
It's worth noting that I initially thought this was a carburetor issue. The carb on this tractor was professionally rebuilt a couple of years ago by a shop in VA that I've had good luck with. But to double check, my son and I rebuilt another carb last weekend that we had laying around. I have the same problems with both carburetors, which I believe rules out the carb.
Thanks for your thoughts!
Colin, Stumped in MN
(quoted from post at 18:59:17 11/17/23)
Looking at your pictures I would recommend a rebuild kit for the governor. The balls in a correctly rebuilt governor do not have flat spots and do not rub on the casing. Once you have the governor adjusted, shimed correctly, per the shop manual see if your governor response does not improve.
Thanks, Bruce! I appreciate the vote of confidence. I didn't know Derek had done that kind of work in the past. I'm going to try my hand at rebuilding it, but will certainly keep your suggestion in mind.
I hope you got the garden tucked in for a much deserved winter break. It's been remarkably warm here. We're still harvesting kale and I have a few carrots in the ground yet. I'd also have collards if the deer hadn't gotten into the patch.
Have a wonderful Thanksgiving!
Colin
My 49 would not throttle down without moving short throttle rod. Further examination showed a sticking butterfly shaft caused by inferior felt aftermarket throttle shaft packing. Temporary fixed with a couple of small O rings.
The fellow who I'm working on this tractor for opted to go the new governor route instead of a rebuild. Governor arrived yesterday and I installed it today. Power issues are solved. Thanks!
Colin
(quoted from post at 21:49:16 11/25/23) The fellow who I'm working on this tractor for opted to go the new governor route instead of a rebuild. Governor arrived yesterday and I installed it today. Power issues are solved. Thanks!
Colin
A new governor that works!? Where did you buy it from?
Jim, I purchased it from this site. I too was concerned, but everything looked pretty good. This is a parade tractor, so it's not going to get the snot worked out of it. That said, I've been working on/with these tractors for 20 years, and in general it seems that the quality of the aftermarket parts has improved. Ten years ago, I wouldn't have touched an aftermarket radiator. I was forced to purchase one (restoration quality) summer of '22 for my 8N on the farm. Since installation, that tractor has cut and raked close to 100 acres of hay and seen daily use in all kinds of weather. It's treated me right so far and I do not baby that tractor.
I personally credit folks like Derek Barkley for doing a lot of work to ensure that parts quality is where it needs to be. I wish (and am willing to pay) for American made parts, but I think there's been a lot of improvement in the overseas parts.
Colin, MN
