rbrashears62
My mother has my grandpa's McCormick cub tractor. Grandma was a truck farmer and used the cub to cultivate his crops. He also had a John Deere 60 for the heavy work.
The serial # on the cub is 100225 with 1800 on the serial# plate. The odd part is the serial number doesn't look like the ones that I found on line. I think that it is a 1950 model. The serial plate maybe the victim of someone cleaning it wrong.
The casting on the side has the code 11 2 8 which seems to be mfg date of November 2, ?
It hasn't been started for about four years but has been stored in a shed during this time. I want to get it running for mom.
Just looking for tips on what to do before cranking it. I am not much of a mechanic can do simple things.
Some ideas.
1. Drain and clean gas bowl. Put new bas in tank. 100% gasoline
2. Change spark plugs and maybe points.
3. Change oil and filter (maybe after I get it running).
4. Check the points
Other things to do?
thanks,
Richie
Some ideas.
4. Check the points
Other things to do?
thanks,
Richie
