scott 1234
Afternoon all: Question ; have you ever replaced the oil pan gasket on a 1966 Cub Lo-Boy? I am about to. [there is some leak somewhere on the bottom of this tractor, i cant see where, so i figured it was time to remove the oil drip pan etc and then see if its there etc]..
if you have this model tractor - you know there are 5 bolts on either side of the pil drip pan.. BUT QUESTION: ARE THER ANY holes /bolts ON THE ENDS of the pan holding it in place?
you see... i ordered a new gasket from Steiner, they said they sent me the right one..- in the catalog picture it shows 12 holes... with 2 pre drilled holes on each end.. interestingly, in what they then actually sent me has zero holes it int at all [not even the 5 and 5 side ones]..
so my first QUESTION; ARE There really any holes/bolts on either end of the drip pan holding it in place? or jsut the 5 and 5 on either side [if there are end holes/bolts how in the world do you get to them, there is no room nor do i see any bolts for them underneath]?]
--other QUESTION; how tight should any bolt be? i worried that these current 5 and 5 bolts would be hard way to take off after all these years- actually i found. they were actually easy. almost too easy. each one turned with little effort of my wrench.
note; i haveNOT taken the whole thing off yet [ why? because if you tell me there really are 2 hidden bolts on either end.. i am like- oh well- how will i ever get to them to remove :0. ] thanks. for advice folks.. i know there is a '66 cub lo boy owner out there with all the know how on all of this stuff :0)
