grease zerks
55 50 Ron
What is the standard (if there is a standard) size of grease zerk threads? I was looking at McMaster Carr and they have many sizes and styles available.
Thank you
the standard ones are 1/8 pipe thread, then the bigger ones are 1/4 pipe thread. then there is those metric ones.
The most common is 1/4 28 bolt thread, then the next bigger is 1/8 NPT, then 1/4 NPT.
Lots of other sizes and drive in with no threads.
Thats what 90 percent of mine are . Makes it easy to retap threads for em or weld a 1/4 inch nut to the piece
Oldest the 1/4 pipe thread, then the 1/8 pipe thread, then the 5/16 drive in and the 1/4 28 thread cane into use after the drive in and now the metric That you get a hold of and think you have the 1/8 pipe thread untill you try to install one and it is slightly too ig. Lots more 1/8 pipe thread used thanthe 1/4-28 size.
Ditto on the 1/4X 28 thread for most common old stuff and new, then the 5mm metric then the 1/8 pipe, which is mostly older equipment and 1/4 pipe is really old stuff from my memory of those things. can't remember what i did yesterday tho so for what it's worth. fred
For the people that say the 1/4-28 is older and more used The McCormick Hay rakes starting in the 20s had drive in fittings, then starting in 39 they had a combination of the drive in fitting and the 1/8 pipe thread. They did not use a 1/4-28 ever on old style rakes that they stoped making in 1950. John Deere omly used the 1/8 pipe thread on rakes fron the Dain up to end of the old style rakes. New Idea used all the 1/8 pipe thread untill just after WW2 when they droped the 3 bar rake and went to the 4 bar and then they only used the 1/4-28 on the bar fittings with the 1/8 being used every ware else. The only place I ever found the 1/4 pipe thread used was on a very first style Massey Harris tractor disk. Massey never used the 1/4-28 fittings on theit takes, only used 1/8 pipe and the drive in.
"What is the standard (if there is a standard) size of grease zerk threads?"
There is no one standard size. There are multiple types and sizes in imperial and metric, threaded and drive in. Manufacturers chose the size and type they want for their product. That's why you see so many in McMaster-Carr.
