grease zert thread
I went to the local Fleet Farm looking for grease Zerts that half a 1/4-20 thread. Non available. The holes that I am planning to install them is a course thread size and everything in 1/4 inch size was 1/4-28. Is there such a thing?
(quoted from post at 15:44:57 11/17/19) I went to the local Fleet Farm looking for grease Zerts that half a 1/4-20 thread. Non available. The holes that I am planning to install them is a course thread size and everything in 1/4 inch size was 1/4-28. Is there such a thing?
Are you SURE it's not 1/4"-18 TPI? They are readily available from various sources, easy to find on-line.
Lots of zerks available in that thread.
A 'net search turned up a few in 1/4"-20 thread, but they are pretty elusive.
You may find the little article below informative.
I have an SAE and a Metric box of Zerks from HF and sometimes I can't get any of them to fit. I like the idea of just taping the thread to suit your purpose. if you have a problem with retrieving your grease gun tip, pulling the zerk out, there is a manual release out there. I have name and number in the shop but I am in for the day. He makes and sells other greasing assistants. Somebody on here will post the name and seller.
the most common zerk is the 1/8 pipe thread. you are talking about course threads, so need more info on what and where u are doing,... as a pipe thread is not course. you cant put grease zerks into a standard course thread.
If you think that, you should see the one grease fitting on my Gravely steering. It is 1/8 thread. Very very tiny fitting. Most assortment boxes the fittings are 1/4 28. I have stuff all of the way up to 1/4 NPT. As you can see they are pretty big. I also have drive fittings in 1/8 3/16 and 1/4. There are a TON of sizes and metric is just as bad. They DON'T interchange. Personally I would go to the Harbor Freight store and buy an assortment box. Around $17.oo. This shows how long I have had this assortment. Keep adding to it. Those drive fittings are great if you know how to drill and install them correctly. You need a hammer.:)
I just removed some zerts from wood straw walker bearings. At first glance they looked like coarse bolt threads. Turns out they are a special wood 'screw' type of thread.Never saw that before...
I guess I should have added some more information. I have collars that have 1/4-20 set screws and I want to replace them with grease zerts. BTW, thanks for all of the comments.
I would not give a tinkers d for a drive in fitting. I have had most of them IH put in pull out with the gun tip when done greasing the fitting. Then I have to take the time to drill and tap for a different fitting.
The cheap fittings are junk. They leave a sharp edge at the top of the fitting. Instead of a rounded edge causing them to not seal well during greasing.
As for a 1/4-20 thread probably available throgh some place like McMaster Carr though would be easier to obtain if they are 1/4-28 common fine thread.
Yep. I think I have some. Don't remember if they were out of an early Gleaner, or Bidwell bean thresher. Either way, they backfired, as grease attracted dirt/grit, and did more damage than good.
I had a similar issue with the fitting on the front axle of a zero turn mower. Took the old one to an auto parts store and they had what I needed. As I recall, it was a fitting used by one of the foreign car manufacturers. Anyway, it worked like a top.
I'd try running a 1/4-28 zerk into the 1/4-20 hole without tapping it. Might put shavings into the bearing from the tap if it's not disassembled. Most zerks are pretty soft and you can probably get 1 or 2 turns before the threads bind and that's enough to hold it in place. a bit crude, but easy.
